Should have been 3amp, they serviced Nov 2024 no faults, so whos fault, they say access was a problem, now I've got a 2 grand problem.
What exactly was the problem?Should have been 3amp, they serviced Nov 2024 no faults, so whos fault, they say access was a problem, now I've got a 2 grand problem.
Don't know, boiler was in when bought the house 5 years ago, BGas reckon 10 years old.Not a chance, who fitted the boiler?
No surprise, I've been advised that they are crapIn the days when I was stupid enough to have a BG annual boiler-service contract, I once had a BG "engineer" (pah!) insist that, in my heating system with a heat-only boiler and S-plan pipework, the central heating and hot water primary circuits were entirely separate bodies of water.
Just realised problem when heating didn't come this morning it was fine last night. Boiler wouldn't switch back on. The boiler is fitted inside a kitchen unit, that's why he was whinging about access to sort it but I thought that the fuse was there to protect any appliance not kill it.What exactly was the problem?
It does sound like a cop out by BG, to not honour a claim.
A sudden electrical fault that would have blown a 3A fuse, would likely have taken out a 5A one too.
From an electrical point of view, a fuse is to protect the wiring to the appliance, not to protect components within the appliance itself.that's why he was whinging about access to sort it but I thought that the fuse was there to protect any appliance not kill it.
Intergas have a 3.15A fuse, but some others such as Vaillant have a 2A fuse either Quick blow or slow blow.Even after all that, boiler PCBs tend to have their own built-in fuses that would probably be to the manufacturers specification. So even if there is a 5A fuse in your FCU, there would likely be a 3A one on the PCB!
Why a £2K problem? Are they pushing you for a new boiler? What is existing make and model?Should have been 3amp, they serviced Nov 2024 no faults, so whos fault, they say access was a problem, now I've got a 2 grand problem.
Yes new boiler advised. He spent about 2 hours and the boiler only stayed on for 20 seconds then off. He said the cost of finding, fixing and replacing possible damage to the circuit boards could end up more than a new boiler and my old boiler may not last even after if the fix was found, the boiler would be Ideal combi swap.Why a £2K problem? Are they pushing you for a new boiler? What is existing make and model?
Yes that's about right, don't know why their service man last year didn't know the 3A / 5A potential problem. Their excuse seems to be that our kitchen fitters had boxed it in restricting access. The Boiler is a combi Ideal approx 12 years old, not home so can't give model No.Can I just check. You have a BG service contract. And they are saying that they won't pay for a repair because it is your fault. So your choices are either to spend a lot of money having the circuit boards replaced, or to buy a new boiler. Which make and model of boiler do you currently have?
