hi guys was wondering if some kind person can give us some information to the following please...
ok,boiler has started to leak water from the pressure release valve when i turn the black release valve to try and shut it off it still leaks,now i have extended the pipe from the valve so it runs through the wall and outside into the drain,so it don't leak all over the floor,this was done when i installed it.until now it's been working fine,i noticed that the pressure dial is dropping as well that could be the leak issue,now would this mean i need to purchase another prv or what?
thanks
brett
on another note can the pressure release valve be stripped down so i can get maybe the dirt out which could be stopping the valve from closing
ok getting another problem now......
the boiler fires up and stays fired up no matter what i do turn down the heat controls for the water and the c/h side.
so i took out the wires for the room stat and put back in the link to isolate the room stat but still fires up and stays fired up,(that rules out the room stat)now could this be a thermostat thats inside the boiler?
thanks
brett
