Its got a JR about 3 inches from the 24S ???
Thanks for being here.........
Boiler turns on, 1 bar water at COLD
If I turn on the central heating, it will work as normal (for a while), but eventually the the flame cuts out, (before) the house thermostat kicks it off. EDIT - So, this means that the boiler just does not seem to do it's job of heating up the house as the flame is cutting out prematurely.
Until it cuts out, hot central heating water is circulated fine.
The safety red light/reset button does not light up.
Even when the flame stops, there sounds like a noise of water still moving, I presume this is the water pump still running at some level and/or will perhaps stop at some point.......
Once the boiler reaches flame cut out point the following occur.
1) IF I turn off the mains and then turn on again, the boiler will start its heating cycle, the flames will go totally high, then will drop to a lower level (we have the central heating boiler rotatey thing setting nearly on the lowest as per the manual)
2) If I leave the boiler to do its own thing, it will start again, for a while.. but still not heat the house enough (because the flame cuts out again and again)
The cycle continues like that.
I would think that it is overheating for some reason and this causes a triggering of a cut out, BUT NOT the red light.
Anyway, I'm only guessing, but that's why I'm here......
PS. During the engineer visit he mentioned something about a diaphragm/membrane as we also have a domestic hot water issue.
I suppose he either talked too quick or I was not listening properly doh!!!!!!!
