I bought a service kit from ebay advertised as BI1011504 original part.
The kit is for the water section which I intend to fit this weekend.
However, the spring loaded bit which is meant to push out a pin to make the DHW switch does seem to have enough movement to achieve this function.
The seller has told me to remove the old one and compare with the new one before returning it
Is there a way to check if the new one is functioning correctly without actually fitting it?
