I have a problem with my boiler the Ch works ok but when running the HW I get a reasonable flow rate but it gets too hot. The temp gauge on the boiler goes up to over 100! and then the cut out button pops out. This happens before I can fill the kitchen sink.
I had an engineer here today, he says that I need a new main circuit board which will cost over £400 and that I should cut my losses and fit a new boiler. £2000 !!!!
I had a quick google and seems to me that the heat exchanger might be blocked. Do you think this is likely? Or is it even simpler like a bust thermistor? Presumably the boiler modulates when heating the water?
I found the circuit board available for £120 and even cheaper on ebay. So I think that I am being overcharged. The boiler is about 8 years old.
Anyone know a good plumber in Bristol?
