biasi 24s ..no hot water
5 Apr 2014
Bristol
can anyone help.. i have a biasi 24s with no hot water , ive changed the diverter valve and the pcb board .. the central heating is working fine . the water from the taps are flowing fine just freezing cold . i took the microswitch off for the hot water and simulated the boiler working and the flame comes on fine .. but when i turn on the hot taps to call for hot water the piston on the diverter valve that operates the microswitch for the hot water dosent come out .... why is this .. how do i fix it?
hello i changed the diverter valve .. the piston was going in and out to start with for about 4 hours then it just stopped..
and just to let anyone when i say i changed the pcb board i ment the flame iginition pcb .. im thinking it could be a problem with the main regulation pcb board but dont think so cos i did see the piston working for a while .. im so confused
Did you take out the gas valve when you changed the diverter valve?
yes fair enough , but can anyone still point out why the piston dosent come out.
i hate gas first and last time i have anything to do with it..
The problem is that we don't know if the boiler is safe now.
I would advise that you get an RGI to come and check it out!
