biasi 24s overheat thermostat switch
10 Feb 2006
Yorkshire
After dhw use the overheat thermostat switch activates and I need to reset it when the temperature gauge falls below 60 degrees.is this a job for an engineer or can I fix this myself?
Should I replace the overheat thermostat because I have had to reset it a number of times and have read that there is a finite amount of times it can be reset before the trip temperature decreases?
Also would this be a job for an engineer or could I do it myself?
