Hi,After use the overheat switch trips but not while the water is running.
The dhw temperature gauge shows 70 degrees with water running but rises to over 80 degrees when it is turned off and then there is a banging noise,the needle on the gauge jumps and the overheat switches in and there is steam escape from the outlet at the top of the boiler. Two weeks ago I put Sentinel x200 in the system,on the bottle it states that it can take 4-6 weeks to work through.
Should I give it another couple of weeks to see or could there be another problem?
