My boiler keeps cutting out on DHW.
Recently I replaced the diverter valve and the heat exchanger has been fully flushed.
I have now diagnosed the fault, but don’t know how to resolve.
The problem is the flow rate.
With the old diverter the DHW flow from the tap could be low and the boiler would stay lit.
Now on low, after about 10 seconds, the flame drops, then cuts out, it then fires back up after about 5 seconds.
If the tap is on fuller, then everything works ok.
CH not affected.
So how can I resolve the flow rate, so as the boiler stays lit, when the tap is on slow flow.
CH not affected.
