Biasi 24s prolem, boiler firing on and off when using dhw
8 Nov 2009
Merseyside
my boiler is a biasi 24s about 11 years old, I have changed dhw diaphram but when I run the hot water tap the boiler fires up for a few seconds then shuts down and carries on doing this therefore the water goes hot and cold not reaching its max temp
Yes it is replaceable but would consult a pro usually cause by debris and crud in the boiler heating circuit so would advise a chemical flush on it after the new part is fitted and a inhibitor once the flush is complete, you also have thermistors on the boiler that could be junked but again to teat would need a pro to test the exchanger you need to measure the heat rise accross the flow and return. Cheers Jordon
