biasi 24s safety thermostat
26 May 2007
Manchester
my boiler stopped working and would not do anything until i pressed the safety thermostat reset button by chance.Have i got a problem that might recurr or will it have just reset?Will this happen again as winter is upon us?
Turn dials on boiler down and make sure your rads are open. Try to find out if it happened during heating or hot water use
Do you mean the overheat or red light ignition lock out which I think these may have?
If you run DHW the temps should not go above about 60°C.
Even if it doesn't the the HE may be scaled up and kettling. In that case the o/h stat will trip AFTER longer DHW useage.
Resetting the o/h stat more than a few times (10-20) will cause it to trip at lower temperatures.
The triping will also be caused if you dont keep the system water at about 1.5 bar and let it got to almiost zero!
Wonderful these devices to protect the boiler from the users!
Tony
