biasi combi boiler
20 Mar 2005
i am haveing problems the water is sometimes cool then other times red hot, can anybody help with this problem and if a part is required what is it
This is a typical symptom of a DHW heat exchanger which is partially blocked on the CH side. It is the result of a failure to properly clean the system according to the British Standards when the boiler was installed or the introduction of new oxygen since.
The cure is to remove and replace or clean the DHW heat exchanger. We charge in the Midlands.
Depending on the severity of debris in the system it may be advisable to have the system power flushed or chemically cleaned to prevent a reoccurance.
We supply new 24 kw heat exchangers for but they can be satisfactorily be cleaned with the right chemicals and skills however we would not recommend this as DIY job.
Tony
Agile Services
MOD
see item 9
