Hi could some advise the fault with my boiler.
It has started to make a buzz sound just as it should fire up but doesn't.
The electronic diagnostic lights show no errors.
Could the relays be not latching? Hence may point to the ignition board? (wanted to attach a video of the fault)
Any help on the matter is greatly appreciated.
Also noticed that the boiler has started to leak again at the gland nut six months after replacing switch, Gland nut, diaphragm. Do you suggest a new diverter valve kit or replacement diverter valve?
Thank you
Grover
Thank you
Grover
