Biasi M90e 24s - Boiler runs but no ignition spark
NEVER blow into the APS!
Its a precision device and you will damage it! Just blow TOWARDS the +ve connection.
Measure the resistance of the C to the NC and then to the NO whilst blowing towards it. Should be less than 1 ohm.
Then you need to find out if the APS is really being operated by the fan!
As a very last resort check the O/H stat has continuity. Its on the right hand side of the main heat exchanger but rarely fails.
If the APS is making when the fan starts then I am afraid it sounds as if its the ignition PCB failed. This will cost about £75 or so.
Tony
