Big vertical cack repair
11 Aug 2012
Berkshire
Here's the story then!
Found an inch wide vertical gap in an upstairs room on a gabled window. Turns out that the brickwork wasnt coursed or tied in so over time a small gap has widened. After exposing I got a structural engineer in who recommended a helifix type fixing. In the end I've elected to use 4x 1m restraint strapping.
Now I'm happy that it won't move anymore but what should I use to fill in the gap between the block work of the gable structure and the brickwork of the wall (upto one inch wide floor to ceiling) before I get the plasterer back in?
I guess my preference would be to use something that's administered by gun, any ideas folks????
Foam does not bond?
Not fire extinguisher foam, expanding foam - the stuff they stick frames in with and other things together with
