    Dismiss Notice
biofold shower door
Discussion in 'Plumbing and Central Heating' started by XanderHarris, 29 Apr 2014.
  1. XanderHarris
    XanderHarris
    4 Mar 2013
    82
    Thanks Received:
    Bradford
    Country:
  2. Sponsored Links
  3. XanderHarris
    XanderHarris
    4 Mar 2013
    82
    Thanks Received:
    Bradford
    Country:
    or will the door hinge open both ways as there is no handle on the door?
  4. stardanny
    stardanny
    14 Nov 2007
    1,657
    Thanks Received:
    254
    Buckinghamshire
    Country:
    I've been looking on the instruction and it appear that the door does open, fold in the shower area. This is because there is a shower seal at bottom of doors.
    Daniel.
    • Thanks Thanks x 1
  5. XanderHarris
    XanderHarris
    4 Mar 2013
    82
    Thanks Received:
    Bradford
    Country:
    Thanks I wondered if it would open both way, Can't see how you'd open it once in the shower? As there's no handles.
  6. Sponsored Links
  7. stardanny
    stardanny
    14 Nov 2007
    1,657
    Thanks Received:
    254
    Buckinghamshire
    Country:
    Possible the middle has finger grip rail all the way from top to bottom...
    Daniel.
    • Thanks Thanks x 1
  8. XanderHarris
    XanderHarris
    4 Mar 2013
    82
    Thanks Received:
    Bradford
    Country:
    Finger grip so you can pull the door inwards will your in the door?
  9. stardanny
    stardanny
    14 Nov 2007
    1,657
    Thanks Received:
    254
    Buckinghamshire
    Country:
    Yes, when you in the shower, you pull the finger grip toward you and the door open, fold into shower area to get out. To get in shower, if the shower door is close, just push middle area of doors away from you to get in.
    Daniel.
  10. XanderHarris
    XanderHarris
    4 Mar 2013
    82
    Thanks Received:
    Bradford
    Country:
    Thanks to set up the wall channels on either side do you just measure 15mm from the end of the tray in and level up?
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
