Bit clueless, landing pad adjacent to house. Where to start?
1 Oct 2010
Cleveland
I currently own a detached property which has a lean-to shed and adjacent to the property is as an area which is best described as a landing pad. It has a concrete floor, Brick wall and gates onto the road and a wooden fence around the edge.
Id like to do something with it, either build a garage or an area which to protect my car from the elements.
I have a few questions which you guys may be able to give me a hand with:
1) Is there any type of building I can construct which would not require planning permission (ie below a certain height, something with no sides or material)
2) If I decided to go the whole hog as a real rough estimate how much would a 1 story garage of this size cost without power? (I appreciate this is very difficult to estimate....)
3) Any advice regarding other things I should be considering here?
Its usually fairly clear what you can and cannot do without planning permission. http://www.planningportal.gov.uk/permission/commonprojects/outbuildings/ I would interpret that site in the red box as being in front of the front elevation of the property and as such you would need planning permission. Read this too http://www.planningportal.gov.uk/uploads/100806_PDforhouseholders_TechnicalGuidance.pdf page 41 in particular. If you applied for planning permission it may be granted or maybe not.
To have a single skinned garage is gonna be say £6-12K. You could consider pre-fab which would be cheaper but the planners proba wouldn't go for it they prob won't like it anyway). If doing it yourself then maybe £2.5-3.5K.
A carport would be classed as an outbuilding too BTW so same rules apply.
If you can do some rough drawings yourself you can submit a planning application yourself for about £165. Prob worth chatting to the planners and popping along, see what they say.
Frankly you could build a carport and see what happens.
