OK - I kind of know what I'm doing, but am not an electrician and therefore not fully up on the regs. I've trawled through various threads, and think the following statements are true, but could someone just nod their head or otherwise for me, please.
I want to stick a plug socket in my garage, which is also where the fusebox is.....
1) I can run a spur to the mains ring, connecting it at the fusebox, as that seems simplest
2) If I have a double socket, or extend the spur to go to another socket somewhere else in the garage, then I have to have a fused isolator somewhere before the 1st socket. Probably directly above or next to it, I guess
3) If I clip the cable to the surface throughout, I can pretty much run where I want to - It will probably be in the corners of the ceiling and then vertical drops to the sockets.
4) For Part P purposes, I did this all last year.
Does that sound about right. Be kind if not, and is there anything else I've missed out ?
