Hi All,
I have an Accenta6 alarm system and need to remove zone 2 due to the wall being knocked down that contains the door contact. I have opened the box and disconected the wires to Zone 2 including the tamper wires.
However when I go to try and set the alarm now I have the problem that Zone 2 isnt there.
Is there a way I can permanently remove Zone 2 from the system?
I have the user guides etc and it mentions omitting zones but also that the control system can prevent me from turning off a zone.
An engineers manual would be great as I will probably want to install this zone again in the future as a PIR if this is possible.
One other point Zone 2 controlled 2 door contacts the one above and another one which is also no longer required, whereas the main one had a 6 wire going to it the second one just has a 2 wire, I cant see where these join.
Thanks for any help you can give.
Worz
Worz
