Black aligned dots on brickwork
For a two year old new build, the builders did a great job of making it look over 100 years old.
Is it timber framed? North facing? Just on that elevation?
Wall is SW facing and yes, the rust/spots are only on this wall elevation. It’s been a couple of months since but no new spots have appeared, nor have the current spots increased in size.
Just out of intetest, OP, have you tried oxallic acid (bought as crystals from the pharmacy, finishing houses, deco centres and even Amazon and added to water) on one spot? If it is carbon it won't have an effect - if it is iron based it should disappear or at least be reduced in intensity
I reckon you should be OK. If you hit blavk plastic then the DPM is too high - any other services should be deeper in any case
Thanks for the idea, will try this over the coming days.
I have also tried involving the NHBC, but they have no interest whatsoever.
Informed me they do not cover preventative repairs or potential damage
