Blade to cut a clay drainage pipe
15 May 2009
West Midlands
I need to cut and replace a underground drainage pipe. Can someone tell me, which blade would I need for an angle grinder.
Most decent diamond tipped blades will cut salt glaze and clay though not all. Some of the cheaper ones may struggle and burn their way through.
However if it is just a one-off then a regular carborundum blade (stone cutting) will do the trick.
A 9" grinder will only cut part the way through but it is still possible to cut it with a 9", you just need to be creative.
A 12" grinder, armed with a carborundum blade, will eat it
