Blanking nut for stopcock
4 May 2020
A 3/4 inch blanking nut doesn’t fit this ancient stop cock. Would a 22mm one most likely work?
Yup, the old imperials are usually a 1" blank if I remember but with old fittings you can never be sure.
Measure it.
BSP size names are surprisingly different to their measured dimensions, but you can look them up when you know the actual diameter.
Any reason for just blanking off? If you intend to leave it, then it would be classed as a dead leg in the system and stagnant water could develop. The fitting could even be the manipulative compression type.
The 22mm worked in the end.
I am blanking it off because this pipe is connected to the two flats below and want my own feed from the loft separate to theirs.
I will remove the entire pipe section once i get the bath off, and the main pipe has a convenient tee to which I can just put a cap on. Does that sound okay @Chris_W?
