Bleed keys ?
  • Thread starter Thread starter marsaday
  • Start date Start date
M
marsaday
i have 2 older rads in the house and i cannot bleed them. My key is either to big or the bleed valve has rounded off ?
I have tried getting some pliers on the valve but i cannot get to it.
Any ideas if i just need a different sized key or do i have a problem which means getting new rads ?
Does it look like the bleed nipples are moulded in as part of the rad or are they on a metal disc usually polished steel which is wound into the radiatior ?
A piccie would be useful here
If it is the former and you are handy with a welder you could try and tack a nut or bolt onto the end of the nipple and wind it out with a spanner. If it is the latter then just unwind the whole thing using the hexagonal nut built into the bleed nipple body and wind in a new one with a good few turns of ptfe
it is the old style which is recessed. Not the modern screw plates with a nipple on them.
i have read some other posts and reckon i may have a go with a socket set or try grinding a slit for a screw driver (dremel little tool).
Be careful when cutting a slit in it if you then snap it in half along the cut you will have even less to work with
Do you have a pair of needle nose pliers ?
first are you sure your rads need bleeding.
get a decent brass key.then look at the square area,if its recesessed just put key in a vice and file flat until no recess then remove swarf with same file.
works on most old rads as long as no dick head has used pliers.
trust me.i am old.
