I bled air from a radiator only a week ago because the top half was cold and already it is becoming cold again at the top. Why does air keep building up?
Its either being pulled in due to bad system design or a restriction in pipework or it may not be air and is hydrogen.Try lighting the"air" next time you bleed the rad.
