Block paving step
  • Thread starter Thread starter cdh
  • Start date Start date
cdh
22 Apr 2006
West Midlands
I'm constructing a front door step using block paving to match the drive. I have concreted the edging kerbs to form the surround and now need to infill with the paving. The step is approx 4ft x 2ft.
Is it best to lay the paving for the step on a concrete/mortar base or on sand the same way as the drive? However, I will struggle to use a compactor in such a small area.
Use concrete sand (sharp sand, screed sand, grit sand etc) mixed with cement.
Don't make it too wet, just enough water so it binds together.
I always apply this method to narrow pathways also, as using a compactor plate has a propensity to allow the paving to dip in places. The way a small body of paving compacts is unpredictable.
  • Thanks
Reactions: cdh
