Block & render garage - Quick questions please :)
1 Aug 2011
Lancashire
Hi all,
This forum has been really helpful over the years, I've really appreciated the help from others.
I'm sharing my new Garage project over on a build thread, but I'm after a bit of advice before I start. Just 3 questions if someone more knowledgable could give up a little time :)
  1. There'll be a DPM beneath the slab. Walls built with grey block. Is there a need for a DPC in the walls? After the first course of blocks?
  2. Is it easier for the brickie if I design the wall dimensions in "whole bricks"? What's the usual allowance for mortar with standard solid blocks?
  3. Once the slab is laid and the formwork removed, there'll be a gap between the new slab and the existing drive. Could I fill this with gravel to act as a soakaway, or is it bad to encourage water under the slab?
    There are no drains anywhere near the garage, so I'm wondering where the rain should run. Run-off is ever so slightly away from the house, towards the garage and the road. I don't want water to run against the new building, but I'm not sure about channeling it out across the footpath either (I'm thinking about ice for pedestrians in winter). Any ideas?
Thanks for your help :)
Chris
Yes. Two engineering brick courses above the slab depending upon ground levels etc.
A block and a joint equates to 450mm horizontally and 225mm vertically.
Are you building foundations?
Dig a soakaway and run the storm into that.
What ground are you building on? 300mm seems awful shallow for the footings. If you're on clay a soakaway won't work, you'll need to connect guttering to the house drainage. Wouldn't worry too much about the groundwater dropping into the joint between garage and house, if your gravel trench doesn't work then put an ACCO drain in & connect it to wherever the guttering drains to (soakaway or mains)
