Block work workshop footings ?
18 Aug 2025
Hi guys so im wanting to build a 4mx 3m by 2.5m tall single skin block work , workshop in my garden ive a 100mm concrete pad thats been down in my garden awhile
the building will be around 12 inch away from my neighbours boundary wall
from what i can gather i wont need planning permission but seems im likely to fall into building regs if it gets flagged due to how close its going to be to the boundary
for the building im looking to do , do i really need 700mm concrete footings... or is the chance that the 100mm pad ive had down for years would be fine to build straight onto of...
Dependant on your soil and presence of trees you could be looking at >>700 if following NHBC guidance.
<30sqm you don't need BR but you do need fire resistant construction.
I wouldn't chance 100mm slab if t'was mine.
It seems you do need Building regs even if its under 30sqm if its going to be less then 1 meter from a boundary
I dont want to risk a rebuild no...
But i also dont really want to break out all the pad thats in and have to pour mega footings
Dig a test pit at the edge of the slab and see what's what.
You could save some digging by doing a pad and beam foundation, but you'll still have to dig holes for the pads, then the expense of steel beams, rebar or massive concrete lintels. When you come full circle you'll probably decide that digging a foundation trench is the easiest option by far.
You don't need to rip out the entire slab, you could carefully cut away the edges and dig down and slightly underneath, if the ground isn't poo.
The other option is to abandon the blocks idea, just build a couple of courses of brick off the slab, and put up a timber framed shed, you could use metal cladding sheets or fibre cement cladding to meet the 'substantially non-combustible' rule, insulate between the studwork for bonus thermal and sound insulation, and fire resistance.
