I've searched extensively and not found exactly what I want, so apologies if I'm repeating ...
I had an intermitent cold rad, so I drained the system, took the rad off and flushed it. Refitted and filled up, or so I thought. Heard an aweful noise from the pump so switched off. I have a new pump, but before I fit it, would I be right if I opened the upper valve I should get clear water from the F&E tank? No water, so I am assuming that the pump failed because of a blocked cold feed, and the cold rad because the pump was beginning to fail?
So, with the pump removed, can I poke up the cold feed pipe to try and unblock? Or is there another problem I haven't considered?
