We bought our house 6 years ago and have had no issues with any drainage, until now. Outside my utility room the ground has started to flood. I called an emergency drainage company out who have given me some very bad news.
They believe that the utility room, which is a small extension, has been built over a man hole. Both my next door neighbors have man holes, and if you were to draw a line between them then the sewer goes straight through my utility room. They opened up both neighbors man holes to try and clear the blockage but their drains are working normally.
The drain man has said that the way the pipe work has been done is wrong in every sense. He says the only solution is to to dig up the ground to see what has has caused the blockage. He has suggest to place a new man hole cover so that this access issue is not a problem again. He has used a pressure pump to try to clear the blockage.
Obviously I am very desperate as the water is not far from the door level so I don't think I have much time to get quotes. He has said it is impossible to quote for as he doesn't know how deep he might have to dig, or what he will uncover. He said in an absolute worst case scenario it could cost up to £2500, this include installing a new man hole.
Can anyone suggest whether the work he intends to carry out sounds right, and if so whether I am being ripped off?
I have uploaded a picture showing the area which has been flooded, this picture was taken just before the flood as I was getting quotes to replace the cast iron down pipe as it is cracked.
