Am waiting for neighbours to get home as have no idea where the manhole is.
Would you suggest i try the toilet snake thingy? Or take up my friends offer (is a plumber just not in the area right now) to remove toilet and access pipe that way?
no, but it seemed a reasonable guess to help the OP. I'm sure if on further inspection she can't locate a large pipe on the outside of her house she will have the sense to post back.
Removing toilet inside house is about the last thing to consider since you've no idea what's trapped behind the bend waiting to pour out onto floor surfaces. failing getting a snake around the bend to pull back what's causing the blockage, I'd go for the caustic method as a option, but only if the water is managing to drain away - even if only slowly. If it cannot drain away you will be left with a highly corrosive medium waiting to cause an accident.
The upstairs toilet is fine alongside every other sink/bath etc
The toilet when flushed water level comes up to scaringly high levels but then whooshes right down really quickly to quite a low level, should i still try the hot water?
