I wish to block up the entrance to an upstairs cupboard. This entrance is built into a brick wall and I would like to block it up with masonry rather than with studwork (I thought aeriated blocks would do). This means building on top of the timber wall plate. Can I just lay the first row of blocks onto the wall plate using ordinary mortar or is some special method of preparation required. It is a Victorian house and as far as I can tell, the rest of the first floor brickwork rests on the wall plate.
Also, the first floor joists run under the opening so at this level I cannot lay blocks across the entire opening, only between the joists. Could this compromise the stability of the new blockwork ? If so, what is the solution ?
