Blomberg integrated heat pump tumble dryer...dead...advice needed please
1 Jan 2010
London
Hi All,
I have an integrated Blomberg heat pump tumble dryer model LTIP07310 which is 3 months out of warranty. It was working fine until the other day when it simply died. No lights on the display, nothing. I checked the fuse and that was fine. I confirmed mains 240v was running into the machine by taking the top off. Whilst I had the top off I gave it a good clean which involved tipping the machine forward and loads of water poured through the fins of the heat exchanger. It's meant to be pumped directly outside via the included hose (which I did check was installed correctly without any blockages). The unit is still dead. Can anyone shed any light on what I can check next?
Cheers
Daz
How far into the machine did the supply reach. Was there an input to and output from the suppressor. Not familiar with your machine but does the door being open cause a similar situation. Just wondering if you have problems with the door interlock or switch actuator.
If it helps in diagnosing your problem there are exploded parts diagrams for your machine here https://www.ransomspares.co.uk/parts/brands/blomberg/tumble-dryers/ltip07310 (7188301930)/
