Hi All,
We have an outside wall - part retaining as house is lower than the road, and it is topped off with red engineering brick - ie smooth and slightly glazed - laid on their side. They are not solid. Our neighbour has the same.
I noticed the other day a large number of these bricks have blown their faces. The house is only coming upto 6 years old and although the weather has been bad recently I would have thought that modern bricks should have had greater resistance and last a lot longer than this. our neighbours are the same and one of their bricks has basically shattered through the whole of the body.
To be honest, I always thought the cement on the wall was very soft and sandy and they suffer terribly with moss which when you pull it off pulls chunks of very red cement out with it - could this be the cause of it?
Also a bit concerned that we have the same bricks in another wall where only a couple of bricks have blown although this is a full retaining wall between our neighbour and ours (about 3.5" high) - again as caps and also suffers moss. Only the odd one of these is blown
Any advice/thoughts greatly appreciated
Regards
L
Regards
L
