Boiler Boom!
27 Nov 2003
My Potterton ProMax 24 He boiler starts up fine in the morning (ie starting up from cold) but on subsequent start ups it can start with a loud booming noise. I hear the fan start, then I can hear the ignition system clicking away. In the morning you hear a couple of clicks and then it ignites (quietly) but later in the day the clicks continue and the tension rises as I wait for the boom that tells me it's lit.
Is this a feature of Potterton boilers or is something wrong? I'd appreciate any advice.
Ian.
Something's wrong. I fix oil boilers, and I know nothing about gas boilers, but this sounds like an incorrect fuel:air mixture, though it could be an ignition fault. You should get it looked at.
This is a common problem. If there's a yellow jumper on the PCB it needs to be removed. This slows the fan down, resulting in lower burner pressure and hence smoother ignition.
