Hi everyone
As I have a bit of time off I am in the process of sorting out my central heating. The problem is I appear to have sludge (black iron stuff) in my radiators as they are heating up at the top but not the bottom. So i went and got some fernox central heating restorer, drained the system and refilled with said fernox.
anyhow its been running for 2 days now and I can't see any improvement?!? However I shall give it a week.
Because I'm impatient, I took one radiator off and drained it and low and behold a load of black water came out which when dried turned to this powdery kind of stuff. when i put that radiator back on the wall after I flushed it with my powerwasher the performance was much better and was only cool for the bottom 40mm or so.
My problem is the massive radiator in my living room which is fed by microbore has the worst performance in the entire house, its real cold at the bottom but untouchable at the top. I am just deciding whether or not to take the plunge (risk carpets!) and take it off the wall or let the fernox do its trick?!? Any advice greatly appreciated.
On the same note, while I was in the plumbing merchants, they had on display a jar of black stuff and magnaclean, is this device any good? I am considering fitting one if it will reduce all the sludge in my system.
Also I am considering changing boilers and I have had my heart set on a Viessmann one, mainly because on those american DIY shows they always have them and my friend has one and even though its power output is less than mine, I swear blind her radiators and DHW heat up way faster than mine in a similarly sized house.
Currently I have a glo worm ultimate. the only problems I forsee are the plumbing (my boiler has the return and flow coming out the top) and the flue, my boiler has it coming out of the side whereas all the new boilers seem to have it coming out of the top and then into a right angle.
Obviously I'm not going to attempt the gas work myself but as I have enrolled on a plumbing course and got an A* for my soldering I thought I may as well hang the boiler and plumb the pipework!
thanks in advance
Lorraine
thanks in advance
Lorraine
