Hi All. Hoping for some guidence here.
Our boiler now runs constantly. Also, with just the HW on we seem to get some heat 'leaking' into a few of the rads.
Ive had a problem since early spring and Ive been 'bodging' by turning off fused spur to system when we didnt want hot water. Now we need heating Misses has given orders that Ive got to sort!
Boiler is Potterton Suprima 100L with Drayton Tempus 7 timer.
My DIY assumption, as an IT person, is that the zone valve to the CH is probably stuck partially open, right or wrong? The bit Im really not sure about is that there are 2 seperate one port valves for a single CH zone. I.E single pipe Tee's and there is then a single port valve on each side it then Tee's back to a single pipe.
Im guessing this isnt to increase overall flow, so assume they do different jobs. One maybe for frost overide?
The CH valves are labelled as Drayton ZA6. The HW zone valve is different, a Honeywell V4043H1056.
Im I barking up the right tree? If so any tips on how I prove where the problem is?
Cheers for any help!
Dave.
Dave.
