Starting conditions
1. Garage air temp (according to digital thermometer) 7.8°C
2. Water temperature in Boiler approx. 55°C
3. Garage Honeywell T4360 Froststat set to 5°C
4. Garage Honeywell L641B1004 pipestat, set to 20°C
5. System controller set to
heating on continuous (so demand controlled by hall thermostat)
6. The Froststat was replaced by Worcester Bosch this month.
The Thermostat in the hall turned down to below 15°C (NO heating demand) and the Water demand set to OFF at the system controller in the Utility room. The pump was running!
I turned the dial on the froststat down. At 3°, the froststat ‘clicked’ and the boiler ignited for approx. 30 seconds. The water temperature rose by about 7°C (55°C to 62°C), according to the boiler.
Question: This appears to be the boiler operating Frost Protection. But why does it happen when the Pipestat, which is wired in series with the Froststat, should be open, as the water temperature is above the 20°C setpoint?
Question: Is there another protection device in the boiler that initiates the Frost Protection cycle, even though the external froststat and pipestat have not demanded it and the temperature dial on the boiler is NOT set to *?
Question: Should the froststat have wires connected to terminals 1, 2 and 3? This is not in accordance with the circuit diagram in the T4360 Reference guide where terminal 2 is not used? If not, could this cause our problems?
Question: Could the terminals of the pipestat have welded closed so that frost protection demand is controlled only by the froststat (this would explain why the Frost Protection operates even when the temperature of the water in the boiler is above the 20°C set point). I have bought a replacement pipestat.
Generally, in winter, our garage is cold and the central heating pump runs all the time, irrespective of demand. In summer, it runs only when there is a demand for heating or water. (except if the garage gets really warm in the winter or cold in the summer). In the warmer weather, we have no issues.
Question: Does the boiler control the operation of the pump?
Question: Why does the pump run after the 3 minute boiler overrun time when there is no heat or water demand?
