So you cannot tell us how to do it. Maybe that was asking too much of you, perhaps an easy option would be for you to list some informative YouTube links.
sorry to have started a bit of a discussion.... The only reason I'm trying to diagnose it myself is that Ive had 3 experts charge me an arm and a leg to achieve nothing. I'm running out of professionals to ring! I'm a mechanical engineer but electrics is beyond me but thanks for posting the wiring diagram, it might save me getting fed any more bullshit. Could I expect the average electrician to understand the system? Thanks.
he needs to be able to read wiring diagram and what additional components are doing
He will need to know how to use a multimeter, have understanding of Y plan operation hence I posted the internal wiring diagram of the valve that clearly shows how the valve works and why the heating does not function with hot water at temperature or off at the programmer
It is a pity there is a lot of useless chatter that detracts from those seeking help, some even wander away getting even more confused.
Thanks DP. I'll give a trusted sparky a ring now I have your wiring diagram. Probably have to wait til after Crimble now but at least I can fire the boiler up by running off hot water. Just have to keep cleaning things!
