I have a Baxi Solo 2 boiler. I have had some trouble with my central heating system for a while and now seem to be chasing my tail. Problem: the central heating runs for about 20 minutes and then the boiler/pump stop. Rads upstairs are piping hot, 4 of the 5 rads downstairs are hot too, the last one is warm but cooler than the others. The boiler stops before the room stat should cut in. Fitted a new pump yesterday (set to speed 3), no leaks, cleared a partially blocked line from the pump to the F&E tank. All rads bled well, hot water tank air bleed ok. I have tried removing an air lock if there was one by: closing both valves on a rad fitted with a drain tap, open drain then open either one of the valves (but not both at the same time). I have even tried back filling the system by fitting a hose to the same rad and filling until water runs out of the overflow pipe on the F&E tank. Once things have cooled down the (several hours later) the heating comes back on albeit briefly. Help, help, help!
