Hi, I currently have a boiler ( Ocean Alpha 240P boiler ) with a normal 24 hour timer. This is set the same every day. However I want the timer to have different times over the weekends. Since its not a 7 day timer. Can I use an external 7 day timer such as this one on ebay ( http://www.ebay.co.uk/itm/24HR-7-DAY-DIGITAL-PLUG-IN-TIMER-SWITCH-SOCKET-TG77-NEW-/300661586855 ). The boiler is currently wired directly into the house mains. I can't see anything wrong with doing this, but am I missing something simple? Is it a simple case of adding a plug to the boiler and a wall socket and then using the 7 day timer adapter making sure the fuse is correct on the timer and plug?! Would boilers start going funny if it gets switched on and off like that via the external timer?
Thanks in advance, any help appreciated.
