Hi.
I have a problem with a boiler.
I have a Glow worm Hot water 100 Express which is sited on an external wall with a horizontal flue. I am building an extension on the side of the house where the boiler flue is and so need to extend the flue through the extension an out of the new external wall.
The problem I have is that a flue extension kit is not available.
When I have asked whether another type of flue will fit I have been told that it wont. The question I have is why ? I have took the cover off over the flue and it would appear that there is a 60mm flexible pipe held to the fan housing with a jubilee clip. This then runs through a 100mm pipe.
Can a different flue be adapted to connect to the flexible pipe, or can it simply be extended with a length of 60mm pipe and a length of 100mm on the outer.
I really don't want to buy a new boiler for the sake of two simple pipes !!
Many thanks. Simon.
Many thanks. Simon.
