boiler flue
18 Feb 2006
Birmingham
Neighbour just had the same boiler as us fitted (vailiant 837 condensing).
Out flue is about 100mm protruding from the wall, where his is like 250mm. Its just a standard horizontal flue
Is that ok or not??
He has it installed in the same place we had ours (kitchen)
If your flue is the standard 100mm, then it should protrude about 87mm from the wall.
How high from the floor is you flue terminal?
Have you got a terminal guard fitted?
Does your neighbours flue terminate in the same position as yours?
Andy.
Its not very critical but a short distance of less than 100 mm is neater.
If your neighbour's flue is 250 mm then it sounds as if the installer is lazy and has just not bothered to cut the flue to the correct length.
Its hardly a gas safety issue and CORGI could probably not insist on the installer doing it correctly even if the installer is registered ( which he may well not be! ).
If there are certain conditions eg; long soffit or overhang directly above then MIs make allowance for this.
I too have left the flue long for these reasons, certainly not because I was lazy or couldn't be bothered to cut it :roll:
I always inform the customer about this at the time of quotation though in case they may not like the look of it.
