    Dismiss Notice
Boiler issues
Discussion in 'Plumbing and Central Heating' started by monty9120, 19 Apr 2016.
Thread Status:
Not open for further replies.
  1. monty9120
    monty9120
    1 May 2015
    65
    Thanks Received:
    Birmingham
    Country:
    Hi all have a Worcester Bosch 28 junior boiler. A few weeks ago it started acting up the wireless thermostat called for heat but it fires and runs but the heat is only Luke warm through the pipes
    Reset the boiler and it's been fine for a few weeks
    This morning wore up to a freezing house. Checked the boiler was running and it was but again only Luke warm the firing light is on as well. Managed to get it working again but I feel it's problems to come
    I have renewed the batteries in the thermostat just in case
    Any ideas what normally goes wrong for this to happen
    There's no fault lights on the boiler
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    11,072
    Thanks Received:
    2,195
    Oxfordshire
    Country:
    Probably a stuck diverter valve, pretty sure it's made of plastic like most other parts on this sh!tbox - they tend to wear out
  4. St0rmer66
    St0rmer66
    11 Apr 2014
    2,951
    Thanks Received:
    661
    Yorkshire
    Country:
    28i Junior doesn't have a diverter valve!
  5. Agile
    Agile
    26 Jun 2004
    63,560
    Thanks Received:
    4,511
    London
    Country:
    I find them very confusing.
    So which Junior has the plastic diverter valve at the right|?
  6. TCCHeating
    TCCHeating
    4 Mar 2013
    2,883
    Thanks Received:
    709
    Country:
    Check your photos tony. I'm sure you will have taken a picture of the last one you worked on;)
    • Like Like x 3
  7. Steelmasons
    Steelmasons
    10 Oct 2011
    16,405
    Thanks Received:
    3,969
    Country:
    :ROFLMAO::ROFLMAO:
  8. St0rmer66
    St0rmer66
    11 Apr 2014
    2,951
    Thanks Received:
    661
    Yorkshire
    Country:
    28i Junior is a standard efficiency combi with bithermal heat exchanger.
    "Greenstar" denotes that it's a condensing boiler with Worcester.
  9. St0rmer66
    St0rmer66
    11 Apr 2014
    2,951
    Thanks Received:
    661
    Yorkshire
    Country:
    Particularly the PCB on this model. Melted APS is a common occurrence.
  10. Sponsored Links
  11. simond
    simond
    26 Oct 2004
    5,232
    Thanks Received:
    465
    Surrey
    Country:
    Bithermic heat exchanger. No plate, no diverter valve.
    Now where have I heard that before? Surely that makes a boiler uber reliable?
    Unless it's a Worcester, right? This boiler will be at least 11 yrs old, bear that in mind.
  12. monty9120
    monty9120
    1 May 2015
    65
    Thanks Received:
    Birmingham
    Country:
    the boilers just over 7 years old which makes it ancient apparently lol. fitted a new expansion vessel at the end of last year.
    it doesnt seem to have any issues with hot water though. is it common to get signal problems from the wireless stats
  13. sooey
    sooey
    10 May 2006
    11,475
    Thanks Received:
    865
    Merseyside
    Country:
    It makes it non compliant, unless you have a pretty unusual home. A lot of non compliant boilers were fitted back then in places they shouldn't have been, usually on the cheap.
  14. Agile
    Agile
    26 Jun 2004
    63,560
    Thanks Received:
    4,511
    London
    Country:
    Monty, your boiler is non condensing. Since April 2005 all boiler had to be condensing models.
    Either your boiler was second hand when fitted or it was old stock.
    Either way it was incorrect when fitted 7 years ago.
    I suspect they stopped making them about 2004 or earlier.
    Pretty silly calling both a non condensing boiler and a condensing one a "Worcester 28i Junior" !
  15. monty9120
    monty9120
    1 May 2015
    65
    Thanks Received:
    Birmingham
    Country:
    I always thought a combi boiler was a condenser boiler which mine is
    Anyway any ideas
  16. monty9120
    monty9120
    1 May 2015
    65
    Thanks Received:
    Birmingham
    Country:
    Can you please explain more please
  17. TCCHeating
    TCCHeating
    4 Mar 2013
    2,883
    Thanks Received:
    709
    Country:
    They don't tony. They added the word greenstar for the condensing range.
    Is it silly that you can buy a vw golf. And also a vw golf gti?
    • Like Like x 1
Loading...
Thread Status:
Share This Page
