Boiler - No power
17 Sep 2007
Sheffield
I recently removed the front cover of a boiler (Volkera Linea 24) to inspect and upon replacing it, will not switch on?
Fuse from main supply is ok, and 2 small fuses inside are fine, connections seem ok and now im baffled?
Please help?
Whose boiler is it and why were you "inspecting" inside?
Tony
Its my own, Its not been functioning properly for weeks and since removing the fornt cover its totally died.
Any advice?
Is the display showing anything?
Have you tried resetting it?
Its most likely that you have snapped one of the knob spindles!
They can be turned from inside with a tool until the position is correct but I would not advise you to do this in case you do further damage!
Tony
Correct, the display and idication light are both out.
When the mains is turned off, then back on. Its begins to start up, but then fails. No idiactor or display lights show during this.
