Well it's getting cooler & I've discovered the central heating is not working. I thought it might be the pump (Grundfos 15-50) as it was old & v noisy, so I replaced that Saturday which turned out to be a saga with leaking valves & unable to find drain point for central heating
Anyway pump is now replaced OK. Boiler fires for hot water (eg if thermostat turned up on hot water cylinder) but not for central heating (if room thermostat turned up). Upstairs rads get warm/hot when hot water is on but downstairs rads cold (downstairs is microbore).
Bolier is glowworm fuelsaver 55F
Central heating thermostat is in downstairs hallway
Central heating pump replaced with new.
Rads bled, header tank emptied, cleaned & new inhibitor added.
There is a silver box 'switch' thing (Honeywell) - valve control?? above the pump which has a slider switch manual/auto which I have put on both settings & doesn't seem to make any difference. I have a spare one of these from when there was a suspected fail a few years ago (turned out it was blown programme control) so could try replacing it if it's not too difficult.
Thanks for any advice/tips before I call a plumber out. Cheers. Dave
