boiler not firing up
4 Dec 2004
i have been fitting a new bathroom and drained the cold water tank and the cylinder.
After finishing the work i turned the stop cock back on and filled the tanks back up.
I have a glow worm 80f boiler which now will not fire up, the fan starts but the boiler will now not ignite. It work fine before i drain my hot and cold water off.
Please can you help
thanks
Boiler has nothing to do withthe water on the "tap" side. Did you drain the heating?
i had taken the bathroom radiator off and one of the valves will not shut fully and has been dripping, probably a few litres over the last few days.
Would it just be a matter of bleeding the radiators??
thanks
Direct or Indirect Cylinder? You may have partially drained Hot Water circuit....refill heating? Hot Water circuit, reset Boiler. Call someone who knows what they are doing.......
