Hi, I have a Halstead Ace High, it will only start up when the front cover is removed or partially off.
A typical symptom of the air pressure switch at fault I am informed which is logical, this has been replaced as has the pcb for a different fault,
Anyone experienced this problem before
<Moderator's note:>
This site does not support DIY gas and posts giving advice on gas work, or encouraging or suggesting it, may be deleted.
<Moderator's note:>
