Hello,
Ive recently moved into a new house and have had the whole water system drained down (as ive had to do a few repairs, change radiators...etc).
Anyway ive refilled the system and bled where possible...so all radiators, all bleed valves (both in the cupboard next to the hot water cylinder and in the loft on the boiler feed and return pipes). Also from the drain valves in the airing cupboard and directly above the boiler.
If i put the central heating on and leave the hot water off everything is fine, nice and quiet as you would expect. If i however switch the hot water on all stays ok for about 10 minutes, then i start to hear water rushing down the pipes which are plumbed into my boiler. I can also hear like a gushing noise which i have confirmed to be the pipes in my loft going from the boiler to my hot water tank. If i open the airing cupboard door and listen i can heat water rushing through the pipework. The system doesnt seem water solid.
I also get the odd 'boiling' sound so to speak coming from my hot water tank.
The system is quite new. It was noisy(ish) when we first moved in but for some reason last night was bad. The sounds coming from the whole system was a lot of gurgling, water gushing etc etc.
Any ideas?
Also what settibgs should my thermostats be set to? I read you should set the thermostst on the boiler to nearly max and the hot water tank to 60 degC. This is what i have done. My pump is on setting 1 and my bypass valve is showing (i think) 2/3 open.
Any ideas?
