I recently moved to a house that has a Worcester Bosch Greenstar 24 Ri ErP condensing boiler. It has the standard terminal outlet (part 87161112090):
https://www.plumbcenter.co.uk/product/worcester-bosch-87161112090-terminal-outlet/
The outlet is located underneath a balcony so I was thinking it might be better to extend it so that the waste gases are discharged away from the balcony rather than underneath it.
Would the 1 metre plume extension kit (part 7716191087) be the correct part to use:
https://www.tdlonline.co.uk/Heating...ter-Bosch-Plume-1Metre-Extension---7716191087
If so, would it be a case of simply sliding the plume extension over the terminal outlet and then securing it with the supplied bracket? I cannot tell from any of the photographs online if the plume extension is designed to click into place on the terminal outlet. I have read in a few places that silicone sealant should be used to improve the seal -- is that correct?
Thanks very much for any help you can provide.
