Hi - I'm in the process of removing an old swimming pool from my garden.
I've now arrived at the part where I need to remove the pool plumbing from the cupboard and this is made complicated because the pool pump takes a feed from the boiler to heat the pool.
The question I have is whether I can use that Grundfos pump on the wall as a valve to stop the flow of water from the boiler. The pipe going into that Grundfos pump comes from the boiler and the pipe coming out of the pump goes into the pool equipment underneath it.
Then, that vertical pipe with the little red valve comes back out of the pool equipment into the boiler. That little red valve is (and always has been since I moved here) turned fully off.
Ultimately, I want to remove all of the pool equipment without causing a leak and I'm hoping I can use that Grundfos pump as a stop valve so that I can disconnect the water flow from the boiler into the pool equipment.
I suppose the other consideration is whether by shutting the water flow, I'd case any damage to the boiler?
Any advice would be much appreciated.
